[SOLVED] gdm error
Semua mengenai teknik instalasi Ubuntu termasuk teknik instalasi aplikasinya dan migrasi dari Windows.
riyanpermadi30
[SOLVED] gdm error
Postby riyanpermadi30 » 21 Feb 2012, 06:46
Assalamualaikum wr wb
Setting up gdm (3.2.1-sata-0ubuntu1~git20120219~tista1~oneiric) ...
/var/lib/dpkg/info/gdm.postinst: 79: /usr/bin/dconf: not found
dpkg: error processing gdm (--configure):
subprocess installed post-installation script returned error exit status 127
No apport report written because MaxReports is reached already
Errors were encountered while processing:
gdm
E: Sub-process /usr/bin/dpkg returned an error code (1)
gan aq bingung setiap instal paket mesti gini knp ya?
tolong solusi nya aga saya bisa instal paket lg
terimakasih gan :grin:
aq tunggu
Re: [ASK] gan ini knp?
Postby thrvers » 21 Feb 2012, 08:39
$ sudo dpkg-reconfigure gdm
riyanpermadi30
Postby riyanpermadi30 » 21 Feb 2012, 10:00
gan hailnya begini
/usr/sbin/dpkg-reconfigure: gdm is broken or not fully installed
dgm aq rusak ta?? ya gan :confused:
Postby abu_unaisah » 21 Feb 2012, 10:08
sudo apt-get install -f
riyanpermadi30
Postby riyanpermadi30 » 21 Feb 2012, 10:51
agan abu uda ni tp hasilnya tetep
After this operation, 0 B of additional disk space will be used.
gdm
apakah aq harus menghapus file dgm
???? :confused:
kalo aq hapus ntr g ad gdmny dunk
Sudoers
Site Admin
Postby Sudoers » 21 Feb 2012, 11:01
Coba deh klo konek internet
sudo apt-get install --reinstall gdm && sudo dpkg-reconfigure gdm
Kalo masih error coba
apt-get clean
apt-get update
Ada error ngak?
Postby abu_unaisah » 21 Feb 2012, 11:04
kalo
sudo dgkg --configure -a
blackshirt
Postby blackshirt » 21 Feb 2012, 11:06
/usr/bin/dconf itu masuk paket dconf
riyanpermadi30
Postby riyanpermadi30 » 21 Feb 2012, 11:06
agan hasilnya sama ni g bisa
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend requires a screen at least 13 lines tall and 31 columns wide.)
debconf: falling back to frontend: Readline
gdm
emang knp ya?
aq cek di google file dgm di hapus trus install lg tp ragu aq
riyanpermadi30
Postby riyanpermadi30 » 21 Feb 2012, 11:08
gan blackshirt trus aq harus gmn? :confused:
riyanpermadi30
Postby riyanpermadi30 » 21 Feb 2012, 11:10
agan abu
riyan@riyan-MS-7388:~$ sudo dgkg --configure-a
sudo: dgkg: command not found
g ad coman dgkg
Sudoers
Site Admin
Postby Sudoers » 21 Feb 2012, 11:11
Pas ngejalanin ini hasilnya apa?
riyanpermadi30
Postby riyanpermadi30 » 21 Feb 2012, 11:12
ini agan hasilnya aq copas semua ya
riyan@riyan-MS-7388:~$ sudo apt-get install --reinstall && sudo dpkg-reconfigure dgm
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
gdm
:grin:
riyanpermadi30
Postby riyanpermadi30 » 21 Feb 2012, 11:16
oya aq dulu perna add ppa untuk gdm ppa ini
http://ppa.launchpad.net/tista/gdm-testing/ubuntu
apa ini krn aq add ppa?
jadi crash dgmnya?
tetapi setaip habis DL paket mesti error seperti i2
blackshirt
Postby blackshirt » 21 Feb 2012, 11:22
$cd ~
$wget http://free.nchc.org.tw/ubuntu//pool/un ... -2_all.deb
$sudo dpkg -i dconf_0.5*.deb
$sudo dpkg-reconfigure dgm
riyanpermadi30
Postby riyanpermadi30 » 21 Feb 2012, 11:33
alahamdulilah, agan blackshirt terimkasih suda berhasil ni
trimakasih juga buat teman-teman yang lain
:grin:
Users browsing this forum: No registered users and 19 guests
