Install Modem Smartfren ac682 di Ubuntu.
Membahas Perangkat-perangkat keras yang belum dideteksi dengan baik oleh Ubuntu serta solusinya.
khairul_saleh
Postby khairul_saleh » 13 Aug 2011, 12:28
agan2 gw newbie ni mao bagi2 pengalaman tentang cara konekin modem smartfren make ubuntu.
[spoiler]saat pertama dicolokan modem ini masih dikenali sebagai CD ROM terlihat dari hasil dmesgnya
~$ dmesg | tail
[ 867.176562] generic ttyUSB1: generic converter now disconnected from ttyUSB1
[ 867.176585] usbserial_generic 5-2:1.1: device disconnected
[ 867.176762] generic ttyUSB2: generic converter now disconnected from ttyUSB2
[ 867.176785] usbserial_generic 5-2:1.2: device disconnected
[ 877.340071] usb 5-2: new full speed USB device using uhci_hcd and address 6
[ 877.514300] scsi8 : usb-storage 5-2:1.0
[ 878.516154] scsi 8:0:0:0: CD-ROM EVDO ReV A 7.00 PQ: 0 ANSI: 2
[ 878.530105] sr1: scsi-1 drive
[ 878.530413] sr 8:0:0:0: Attached scsi CD-ROM sr1
[ 878.533687] sr 8:0:0:0: Attached scsi generic sg2 type 5
karena itu eject aja CDROMnya
~$ sudo eject /dev/sr1
lihat lagi statusnya
~$ dmesg | tail
[ 943.926200] usbserial_generic 5-2:1.0: generic converter detected
[ 943.926378] usb 5-2: generic converter now attached to ttyUSB0
[ 943.928384] usbserial_generic 5-2:1.1: generic converter detected
[ 943.928562] usb 5-2: generic converter now attached to ttyUSB1
[ 943.930198] usbserial_generic 5-2:1.2: generic converter detected
[ 943.930378] usb 5-2: generic converter now attached to ttyUSB2
[ 943.932556] scsi9 : usb-storage 5-2:1.3
[ 944.936159] scsi 9:0:0:0: Direct-Access EVDO ReV A 7.00 PQ: 0 ANSI: 0 CCS
[ 944.937672] sd 9:0:0:0: Attached scsi generic sg2 type 0
[ 944.948148] sd 9:0:0:0: [sdb] Attached SCSI removable disk
yippi, sudah terdeteksi :D
lanjut cek modem via lsusb
:~$ lsusb
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 15d9:0a4c Trust International B.V.
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 009: ID 19d2:ffdd ONDA Communication S.p.A.
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 004: ID 0bda:8197 Realtek Semiconductor Corp. RTL8187B Wireless Adapter
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 04f2:b120 Chicony Electronics Co., Ltd
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
diketahui status modem
lanjut ke pengaturan
masuk ke
~$ sudo gedit /etc/usb_modeswitch.conf
tambahkan kode ini di baris paling akhir
# /etc/usb_modeswitch.conf
# Smart ZTE AC682 (EVDO)
DefaultVendor = 0x19d2
DefaultProduct = 0xffde
TargetVendor = 0x19d2
TargetProduct = 0xffdd
MessageContent= 5553424312345678c00000008000069f030000000000000000000000000000
masuk lagi ke
~$ sudo /etc/udev/rules.d/99-zte-ac682.rules
isi dengan
# /etc/udev/rules.d/99-zte-ac682.rules
SUBSYSTEM=="usb", SYSFS{idVendor}=="19d2",
SYSFS{idProduct}=="ffdd", RUN+="/usr/sbin/usb_modeswitch –
sekarang load beberapa parameter yang dibutuhkan ke kernel
~$ sudo modprobe usbserial vendor=0�19d2 product=0xffdd
deteksi modemnya via wvdial
~$ sudo wvdialconf
maka akan menghasilkan :
Editing `/etc/wvdial.conf'.
Scanning your serial ports for a modem.
Modem Port Scan: S0 S1 S2 S3 S4 S5 S6 S7
Modem Port Scan: S8 S9 S10 S11 S12 S13 S14 S15
Modem Port Scan: S16 S17 S18 S19 S20 S21 S22 S23
Modem Port Scan: S24 S25 S26 S27 S28 S29 S30 S31
WvModem: Cannot get information for serial port.
ttyUSB0: ATQ0 V1 E1 -- OK
ttyUSB0: ATQ0 V1 E1 Z -- OK
ttyUSB0: ATQ0 V1 E1 S0=0 -- OK
ttyUSB0: ATQ0 V1 E1 S0=0 &C1 -- OK
ttyUSB0: ATQ0 V1 E1 S0=0 &C1 &D2 -- OK
ttyUSB0: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 -- OK
ttyUSB0: Modem Identifier: ATI -- Manufacturer: +GMI: China TeleCom
ttyUSB0: Speed 9600: AT -- OK
ttyUSB0: Max speed is 9600; that should be safe.
ttyUSB1: ATQ0 V1 E1 -- failed with 2400 baud, next try: 9600 baud
ttyUSB1: ATQ0 V1 E1 -- failed with 9600 baud, next try: 9600 baud
ttyUSB1: ATQ0 V1 E1 -- and failed too at 115200, giving up.
ttyUSB2: ATQ0 V1 E1 -- OK
ttyUSB2: ATQ0 V1 E1 Z -- OK
ttyUSB2: ATQ0 V1 E1 S0=0 -- OK
ttyUSB2: ATQ0 V1 E1 S0=0 &C1 -- OK
ttyUSB2: ATQ0 V1 E1 S0=0 &C1 &D2 -- OK
ttyUSB2: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 -- OK
ttyUSB2: Modem Identifier: ATI -- Manufacturer: +GMI: China TeleCom
ttyUSB2: Speed 9600: AT -- OK
ttyUSB2: Max speed is 9600; that should be safe.
Found a modem on /dev/ttyUSB0.
Modem configuration written to /etc/wvdial.conf.
ttyUSB0: Speed 9600; init "ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0"
ttyUSB2: Speed 9600; init "ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0"
modem terdeteksi di /dev/ttyUSB0 :D
lanjut ke pengaturan wvdial
masuk ke
~$ sudo gedit /etc/wvdial.conf
tambahkan baris berikut
[Dialer smart]
Init1 = ATZ
Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
Stupid Mode = 1
Modem Type = Analog Modem
Command Line = ATDT
ISDN = 0
New PPPD = yes
Phone = #777
Modem = /dev/ttyUSB0
Username = smart
Password = smart
Baud = 460800
langkah terakhir coba koneksi dengan cara
~$sudo wvdial smart
--> WvDial: Internet dialer version 1.60
--> Cannot get information for serial port.
--> Initializing modem.
--> Sending: ATZ
ATZ
OK
--> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
OK
--> Modem initialized.
--> Sending: ATDT#777
--> Waiting for carrier.
ATDT#777
CONNECT 3100000
--> Carrier detected. Waiting for prompt.
~[7f]}#@!}!}!} }3}"}&} } } } }#}%B#}%}'}"}(}"W}0~
--> PPP negotiation detected.
--> Starting pppd at Fri Jul 15 06:54:49 2011
--> Pid of pppd: 5113
--> Using interface ppp0
--> local IP address 10.249.99.173
--> remote IP address 10.20.31.6
--> primary DNS address 10.17.3.252
--> secondary DNS address 10.17.3.244
kalau sudah mendapat ip addrees seperti itu harusnya sudah bisa browsing internet hehe
nah sekarang masalahnya, setiap mau konek kita harus eject cd rom, load ke kernel dll, biar ringkas sekalian aja dibikin bash scriptnya hehe
buat file baru, dinamai terserah asal ekstensi terakhir sh klo punya ane smart.sh biar gampang ingatnya.
isi dengan kode berikut
#!/bin/bash
sudo eject /dev/sr1
sleep 2
sudo modprobe usbserial vendor=0x19d2 product=0xffdd
sleep 2
sudo wvdial smart
parameter sleep diatas berfungsi untuk menunggu proses selama 2 detik. Karena kadang2 setiap proses butuh waktu hehe
yuk, lanjut chmod dulu biar bisa dijalankan
~$ sudo chmod +x smart.sh
untuk menjalankan tinggal ketik
~$ ./smart.sh[/spoiler]
cara itu udh gw buktiin sendiri. dan sukses di ubuntu 10.04 ma 11.04 yg gw pake. moga berguna bagi membutuhkan.
rizaaal
Re: Install Modem Smartfren ac682 di Ubuntu.
Postby rizaaal » 13 Aug 2011, 13:09
sip bro. cara2nya saya baru pernah liat semua tuh. lumayan nambah ilmu. :D temen saya juga pake modem ini, nanti saya cobain ah..
n_dhank
Postby n_dhank » 19 Apr 2012, 09:42
Untuk Insatll diubuntu 12.04 caranya gimana?
Postby abu_unaisah » 19 Apr 2012, 09:49
biasanya sama
dik
Postby dik » 19 Apr 2012, 09:59
kalau modem CE682 mas..??
saya pengen nya via network manager..
udah kedetect tapi kok g bisa connect ya..?
apa yang salah ya..??
dial: #777
username: smart
pass: smart
nah kalo abis pilih negara kan ngisi APN..
lha itu di isi apa ya..?? APN nya?
CDX
Postby CDX » 19 Apr 2012, 11:47
dial: #777
username: smart
pass: smart
APN : "smartfren"
Postby Nexus » 19 Apr 2012, 16:42
dial: #777
username: smart
pass: smart
kalo udah kedetct, tinggal diklik "enable mobile broadband" aja. lalu masuk edit connection, pilih indonesia > SMART > centang connect automatically. jadi setiap mau connect, tancepin modem, kalo udah kedetect, tinggal dicentang aja "enable mobile broadband"
Postby Nexus » 20 Apr 2012, 00:02
dial: #777
username: smart
pass: smart
APN : "smartfren"
apn : SMART
dan138zig
Postby dan138zig » 22 Apr 2012, 08:33
mohon bantuannya, di perintah:
"~$ sudo gedit /etc/usb_modeswitch.conf
tambahkan kode ini di baris paling akhir"
saya malah menghapus semua dan menggantinya dengan kode itu. ada yang tahu cara balikin ke semula?
sudo wvdial menghasilkan ini:
Cannot open /dev/ttyUSB0: No such file or directory
dan138zig
Postby dan138zig » 22 Apr 2012, 16:25
saya udah bisa sampe tahap terakhir, tapi modem not responding mulu. udah direstart, cabut pasang, sama aja. kenapa ya?
Postby Nexus » 25 Apr 2012, 20:40
pastikan paket2 dibawah ini juga sudah terinstall dari synaptic-package-manager....
* sl-modem-daemon
* sl-modem-source
* Modem-Manager
* gobi-loader
* isc-dhcp-client
* ppp
* pppconfig
* usb-modeswitch-data
* usb-modeswitch
* pcmciautils
Postby Nexus » 25 Apr 2012, 20:41
install ulang aja "usb-modeswitch-data dan usb-modeswitch". beres
EFHRALA
Postby EFHRALA » 10 Oct 2014, 01:40
gan kira-kira
untuk modem smartfren jenis lainya dan ubuntu versi lainnya
cara instalnya sama saja atau ada perbedaan
smartfren ane Smartfren Connex DF78AH UI
dan ubuntu yang ane pake ubuntu 10.04 gan
kira2 settingan nya sama atau gk ya gan
mohon pencerahannya gan
"newbie"
Users browsing this forum: Yahoo [Bot] and 2 guests
