[ask]Error Java WTK
SinauUbuntu
[ask]Error Java WTK
Postby SinauUbuntu » 21 Jul 2011, 18:55
Lagi iseng2 nyoba j2me developing.
Tapi dimana2 kalo coba2 pasti ada salahnya...
// Sample adapted from http://developers.sun.com/mobility/midp ... /wtoolkit/
import javax.microedition.lcdui.*;
import javax.microedition.midlet.*;
public class HelloWorld
extends MIDlet
implements CommandListener
private Form mMainForm;
public HelloWorld()
mMainForm = new Form("HelloWorld");
mMainForm.append(new StringItem(null, "Hello, World!"));
mMainForm.addCommand(new Command("Exit", Command.EXIT, 0));
mMainForm.setCommandListener(this);
public void startApp()
{ Display.getDisplay(this).setCurrent(mMainForm); }
public void pauseApp() {}
public void destroyApp(boolean unconditional) {}
public void commandAction(Command c, Displayable s)
{ notifyDestroyed(); }
Error:
Unable to create MIDlet HelloWorld
java.lang.ClassNotFoundException: HelloWorld
at com.sun.midp.midlet.MIDletState.createMIDlet(+29)
at com.sun.midp.midlet.Selector.run(+22)
kenapa ya???
dicari di google adanya penjelasan WTK di "wedous"...
Reason: nambahi judul
dhiemaz_mitnick
Re: Error Java WTK
Postby dhiemaz_mitnick » 21 Jul 2011, 19:17
ClassDefNotfoundException itu error umum yang dikarenakan class atau library yang diperluin ga lo includekan didalam paket jar nya..
SinauUbuntu
Re: Error Java WTK
Postby SinauUbuntu » 21 Jul 2011, 20:06
jadi yang dibenerin apanya?
masih belum paham...
*mohon maklum :)
dhiemaz_mitnick
Re: Error Java WTK
Postby dhiemaz_mitnick » 21 Jul 2011, 21:29
Lo bikinnya ini pake Eclipse atau pake netbeans..? kalo pake eclipse, lo copy semua jar yang berkaitan dengan code yang lo gunakan kedalam projectnya lo ini.
dhiemaz_mitnick
Re: Error Java WTK
Postby dhiemaz_mitnick » 21 Jul 2011, 21:30
coba masukan jar / library ini "javax.microedition.midlet.*;" kedalam project lo..
SinauUbuntu
Re: Error Java WTK
Postby SinauUbuntu » 22 Jul 2011, 18:41
saya pake' Java Wireless toolkit for CLDC...
sudah "import javax.microedition.midlet.*;"
Users browsing this forum: Google [Bot] and 11 guests
