installasi squid proxy di ubuntu server 10.10
BlackRedemp
Postby BlackRedemp » 05 May 2011, 16:34
maaf sebelumnya.
salam kenal buat agan2 semuanya, ane newbie ne.
salam ubuntu! merdeka!
langsung aja gan,
ane udah install ubuntu server 10.10
ane mo install squid proxy,,
tp waktu ane ketikkan perintah,
# sudo apt-get update
munculnya gini gan :
Unable to connect to us.archive.ubuntu.com:http: [IP: 91.189.88.140 80]
Err http://us.archive.ubuntu.com maverick-updates/main Sources
Err http://us.archive.ubuntu.com maverick-updates/restricted Sources
Err http://us.archive.ubuntu.com maverick-updates/universe Sources
Err http://us.archive.ubuntu.com maverick-updates/multiverse Sources
Err http://us.archive.ubuntu.com maverick-updates/main amd64 Packages
Err http://us.archive.ubuntu.com maverick-updates/restricted amd64 Packages
Err http://us.archive.ubuntu.com maverick-updates/universe amd64 Packages
Err http://us.archive.ubuntu.com maverick-updates/multiverse amd64 Packages
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dis ... elease.gpg Could not connect to us.archive.ubuntu.com:80 (91.189.88.140). - connect (110: Connection timed out) [IP: 91.189.88.140 80]
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dis ... ion-en.bz2 Unable to connect to us.archive.ubuntu.com:http: [IP: 91.189.88.140 80]
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dis ... -en_US.bz2 Unable to connect to us.archive.ubuntu.com:http: [IP: 91.189.88.140 80]
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dis ... elease.gpg Unable to connect to us.archive.ubuntu.com:http: [IP: 91.189.88.140 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists ... elease.gpg Could not connect to security.ubuntu.com:80 (91.189.92.167). - connect (110: Connection timed out) [IP: 91.189.92.167 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists ... ion-en.bz2 Unable to connect to security.ubuntu.com:http: [IP: 91.189.92.167 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists ... -en_US.bz2 Unable to connect to security.ubuntu.com:http: [IP: 91.189.92.167 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists ... Sources.gz Unable to connect to security.ubuntu.com:http: [IP: 91.189.92.167 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists ... ackages.gz Unable to connect to security.ubuntu.com:http: [IP: 91.189.92.167 80]
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dis ... Sources.gz Unable to connect to us.archive.ubuntu.com:http: [IP: 91.189.88.140 80]
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dis ... ackages.gz Unable to connect to us.archive.ubuntu.com:http: [IP: 91.189.88.140 80]
E: Some index files failed to download, they have been ignored, or old ones used instead.
root@jayanet:~#
ane minta tolong pencerahannya gan??? please??
terima kasih agan2 semuanya, semoga bisa segera terjawab.
salam kenal dari BlackRedemp
yudiarbi
Re: installasi squid proxy di ubuntu server 10.10
Postby yudiarbi » 05 May 2011, 21:05
konekin internet dulu bro...
blangkon91
Postby blangkon91 » 09 May 2011, 12:34
bener apa yang di kasih tau Gan di atas ane, sama kaya aku dulu juga gitu, hixzzz
wasliyanto
Postby wasliyanto » 12 May 2011, 17:08
salam perkenalan "wasli"
sudah 1 bulan saya coba ubuntu server 9.04 namun belum berhasil
tolong para master sekalian untuk mohon di koreksi instal serta squid
ip proxy 192.168.2.2
ip mikrotik 192.168.2.1
ip client 192.168.0.1
ip modem spedy 192.168.1.3
sudah saya install semua sukses namun pada saat dihubungkan ke clien muncul tulisan
ERROR
The requested URL could not be retrieved
While trying to retrieve the URL: http://www.google.com/firefox?
The following error was encountered:
* Access Denied.
Access control configuration prevents your request from being allowed at this time. Please contact your service provider if you feel this is incorrect.
Your cache administrator is alfanet.
Generated Thu, 12 May 2011 16:42:30 GMT by cikruk21 (squid/2.7.STABLE3)
dan ini squid yang saya pakai
# Proxy Server Versi 2.7.Stable7
# by cikruk21
# Port
http_port 3128 transparent
#untuk facebook
server_http11 on
acl speedtest dstdomain .speedtest.cbn.net
acl speedtest dstdomain .speedtest.net
cache allow speedtest
#icp_port 3130
#prefer_direct off
#tambahan
hierarchy_stoplist cgi-bin ?
acl QUERY urlpath_regex cgi-bin \?
no_cache deny QUERY
# Cache & Object
cache_mem 8 MB
cache_swap_low 98
cache_swap_high 99
max_filedesc 8192
maximum_object_size 128 MB
minimum_object_size 0 KB
maximum_object_size_in_memory 125 KB
ipcache_size 4096
ipcache_low 98
ipcache_high 99
fqdncache_size 4096
cache_replacement_policy heap LFUDA
memory_replacement_policy heap GDSF
mime_table /usr/share/squid/mime.conf
# cache_dir
cache_dir aufs /home/proxy1 25000 30 256
cache_access_log /var/log/squid/access.log
cache_log /var/log/squid/cache.log
cache_store_log none
log_fqdn off
pid_filename /var/run/squid.pid
cache_swap_log /var/log/squid/swap.state
dns_nameservers 192.168.2.1
emulate_httpd_log off
hosts_file /etc/hosts
half_closed_clients off
negative_ttl 1 minutes
#anyar
positive_dns_ttl 1 hours
#ftp mode pasif
ftp_passive on
ftp_sanitycheck on
# Rules: Safe Port
#tambahan
quick_abort_min 0
quick_abort_max 0
quick_abort_pct 98
shutdown_lifetime 10 seconds
acl all src 0.0.0.0/0.0.0.0
acl manager proto cache_object
acl localhost src 127.0.0.1/255.255.255.255
acl to_localhost dst 127.0.0.0/8
acl SSL_ports port 443 563 873 # https snews rsync
acl Safe_ports port 80 # http
acl Safe_ports port 20 21 # ftp
acl Safe_ports port 70 # gopher
acl Safe_ports port 210 # wais
acl Safe_ports port 1025-65535 # unregistered ports
acl Safe_ports port 631 # cups
acl Safe_ports port 10000 # webmin
acl Safe_ports port 901 # SWAT
acl Safe_ports port 280 # http-mgmt
acl Safe_ports port 488 # gss-http
acl Safe_ports port 591 # filemaker
acl Safe_ports port 777 # multiling http
acl Safe_ports port 873 # rsync
acl Safe_ports port 110 # POP3
acl Safe_ports port 25 # SMTP
acl Safe_ports port 2095 2096 # webmail from cpanel
acl Safe_ports port 2082 2083 # cpanel
acl purge method PURGE
acl CONNECT method CONNECT
http_access allow manager localhost
http_access deny manager
http_access allow purge localhost
http_access deny purge
http_access deny !Safe_ports !SSL_ports
http_access deny CONNECT !SSL_ports !Safe_ports
# Refresh Pattern
# pictures & images
refresh_pattern -i \.(gif|png|jpeg|jpg|bmp|tif|tiff|ico)$ 10080 80% 43200 override-expire override-lastmod reload-into-ims ign$
refresh_pattern -i \.(xml|html|htm|js|txt|css|php)$ 10080 80% 43200 override-expire override-lastmod reload-into-ims ignore-re$
#sound, video multimedia
refresh_pattern -i \.(flv|x-flv|mov|avi|qt|mpg|mpeg|swf)$ 10080 90% 43200 override-expire override-lastmod reload-into-ims ign$
refresh_pattern -i \.(wav|mp3|mp4|au|mid)$ 10080 90% 43200 override-expire override-lastmod reload-into-ims ignore-reload igno$
# files
refresh_pattern -i \.(iso|deb|rpm|zip|tar|tgz|ram|rar|bin|ppt|doc)$ 21600 90% 43200 ignore-no-cache ignore-auth
refresh_pattern -i \.(zip|gz|arj|lha|lzh)$ 10080 100% 21600 override-expire ignore-no-cache ignore-auth
refresh_pattern -i \.(rar|tgz|tar|exe|bin|arj)$ 21600 100% 43200 override-expire ignore-no-cache ignore-auth
refresh_pattern -i \.(hqx|pdf|rtf|doc|swf)$ 100000 100% 99000000 override-expire ignore-no-cache ignore-auth
refresh_pattern -i \.(inc|cab|ad|txt|dll)$ 100000 100% 99000000 override-expire ignore-no-cache ignore-auth
refresh_pattern -i \.swf$ 10080 90% 10080 override-expire override-lastmod reload-into-ims
refresh_pattern -i \.3gp$ 10080 90% 10080 override-expire override-lastmod reload-into-ims
refresh_pattern -i \.rm$ 10080 90% 10080 override-expire override-lastmod reload-into-ims
refresh_pattern -i \.wma$ 10080 90% 10080 override-expire override-lastmod reload-into-ims
refresh_pattern ^http://mail.yahoo.com/.* 720 100% 4320
refresh_pattern ^http://*.yahoo.*/.* 720 100% 4320 override-expire override-lastmod reload-into-ims
refresh_pattern ^http://*.google.*/.* 720 100% 4320
#refresh_pattern ^http://pb.gemscool.com/.* 720 100% 4320 override-expire override-lastmod reload-into-ims
#refresh_pattern ^http://ayodance.megaxus.com/.* 720 100% 4320 override-expire override-lastmod reload-into-ims
#refresh_pattern ^http://luna.lytogame.com/.* 720 100% 4320 override-expire override-lastmod reload-into-ims
refresh_pattern ^http://www.facebook.com/.* 720 100% 4320 override-expire override-lastmod reload-into-ims
refresh_pattern ^http://kaskus.us/.* 720 100% 4320 override-expire override-lastmod reload-into-ims
#refresh_pattern ^http://perfectworld.lytogame.com/.* 720 100% 4320 override-expire override-lastmod reload-into-ims
#refresh_pattern ^http://seal.lytogame.com/.* 720 100% 4320 override-expire override-lastmod reload-into-ims
refresh_pattern ^http://*.indowebster.*/.* 720 100% 4320
refresh_pattern ^http://*.4shared.*/.* 720 100% 4320
refresh_pattern ^http://www.yahoo.com/.* 720 100% 4320
refresh_pattern ^http://*.yimg.*/.* 720 100% 4320
refresh_pattern ^http://*.boleh.*/.* 720 100% 4320
#refresh_pattern ^http://*.detik.*/.* 180 100% 4320
#refresh_pattern ^http://*.detikinet.*/.* 180 100% 4320
#refresh_pattern ^http://*.detikhot.*/.* 180 100% 4320
#refresh_pattern ^http://*.detiportal.*/.* 180 100% 4320
#refresh_pattern ^http://*.kompas.*/.* 180 100% 4320
refresh_pattern ^http://*.facebook.*/.* 720 100% 4320
refresh_pattern ^http://*.texas_holdem.*/.* 720 100% 4320
refresh_pattern ^http://*.zynga.com.*/.* 720 100% 4320
refresh_pattern ^http://*.ninjasaga.*/.* 720 100% 4320
refresh_pattern ^http://*.texas.poker.*/.* 720 100% 4320
refresh_pattern ^http://apps.facebook.com/.* 720 100% 4320
refresh_pattern ^http://*.kapanlagi.*/.* 720 100% 4320
refresh_pattern ^http://*.google-analytics.*/.* 720 100% 4320
#default option
refresh_pattern ^ftp: 1440 20% 10080
refresh_pattern ^gopher: 1440 0% 1440
refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
refresh_pattern . 0 20% 4320
# SNMP
snmp_port 3401
acl snmpsquid snmp_community public
snmp_access allow snmpsquid localhost
snmp_access deny all
# ALLOWED ACCESS
#acl cikruk21 src 192.168.0.0/24
acl cikruk21 src 192.168.2.0/24
http_access allow cikruk21
http_access allow localhost
http_access deny all
http_reply_access allow all
icp_access allow cikruk21
icp_access allow localhost
icp_access allow all
always_direct deny all
# Cache CGI & Administrative
cache_mgr alfanet
visible_hostname cikruk21
cache_effective_user proxy
cache_effective_group proxy
logfile_rotate 7
#tambahan
memory_pools on #biasanya off
icp_hit_stale on
query_icmp on
reload_into_ims on
coredump_dir /var/spool/squid
pipeline_prefetch on
vary_ignore_expire on
request_body_max_size 1048 KB
#tcp_outgoing_tos 0x30 localnet
zph_mode tos
zph_local 0x30
zph_parent 0
zph_option 136
yudiarbi
Postby yudiarbi » 12 May 2011, 22:37
mencoba membantu ya, coba2 juga, di bagian :
saya asumsikan ip client2 bos wasli, 192.168.0.0/24
ERROR
* Access Denied.
dari error tersebut diartikan(menurut saya) si client dilarang keras dilewatkan ke modem, di tutup oleh si "cumi", menurut analisa saya di sebabkan pada squid.conf:
dari script itu diartikan yang boleh mengakses jaringan adalah 192.168.2.0/24 yang didefinisikan sebagai cikruk21, padahal ip client 192.168.0.1(192.168.0.0/24), beda segmen beda network, harus di definisikan di squid,conf dan mainin iptables...
itu masih menurut saya bro... :D
Postby sipelaut » 13 May 2011, 06:42
waduhh udah makek mikrotik...
gak berani bantu broo... soalnya lom paham mikrotik
nyimak ajalah.. hee....
wasliyanto
Postby wasliyanto » 13 May 2011, 21:21
sudah saya coba bos yudiarbi menurut penjelasan diatas, disesuaikan ip nya tetap keluar seperti itu, apa mungkin squidnya yang salah bro,tolong dong bantuin mungkin punya squid yang lain yang sudah terbukti bisa, maklum la saya newbie sekali dengan ubuntu server dan squid, sebelumnya saya pakai proxy clearOS 5.2 digabungkan dengan mikrotik sudah sukses dan jalan,kali ini saya masih belajar ubuntu proxy juga digabungkan dengan mikrotik, tolong bro dibantuin
yudiarbi
Postby yudiarbi » 14 May 2011, 02:27
coba di posting skema jaringan lengkap plus ip2nya..., mgkn bisa kita tela'ah bareng2..
wasliyanto
Postby wasliyanto » 14 May 2011, 09:11
192.168.1.2 192.168.0.1
Modem spedy-------------------Mikrotik-------------------Wifi
192.168.1.1 192.168.0.253
192.168.2.1 -----------------------------
Proxy Ubuntu
192.168.2.2
Mikrotik
192.168.1.1 (gatway di mikrotik)
Ether5 -192.168.2.1/24 ke proxy ubuntu
Ether2 -192.168.0.1/24 ke wifi
Ether3 -192.168.1.2/24 ke modem speedy
DNS mikrotik
180.131.144.144
180.131.145.145
Seting nat di mikrotik
/ip firewall nat add chain=srcnat out-interface=ether3 action=masquerade
/ip firewall nat add chain=dstnat src-address=!192.168.2.0/24 protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.2.2 to-ports=3128 comment="Redirect_Proxy_WiFi" disabled=no
Nb: setingan mikrotik diatas sudah bisa jalan dengan proxy clearOS 5.2 standlone no firewall
Ubuntu server 9.04
IP 192.168.2.2
255.255.255.0
192.168.2.1 gatway
Name dns 192.168.2.1
CPU ubuntu:Pentium 4, proc. 3 G, ram 512, hardisk sata 80G
Partisi hardisknya ubuntu
#1 Primary 4.0 GB ext4 /boot
#2 Logical 4.0 GB ext4 /
#3 Logical 4.0 GB ext4 /var
#4 Logical 4.0 GB ext /usr
#5 Logical 1.0 GB swap
#6 Logical 30.0GB /home/proxy1
#7 Logical 33.0GB /home/data
Saya ngambil tutorial dari web:
http://kumpulan-tutorial-mikrotik.blogs ... squid.html
maaf gambar topologinya ga jelas(ngajak)
yudiarbi
Postby yudiarbi » 14 May 2011, 10:12
kayaknya di bagian ini :
tanda seru diilangin
smpyn ubah natnya dengan konsep pake src-address yaitu yang akan diproxy adalah yang dari eth3 yang sudah dihandle oleh mikrotik di nat ke port80 address server proxy ports 3128
/ip firewall nat add chain=dstnat src-address=192.168.1.2 protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.2.1 to-ports=3128
mgkn bisa membantu
wasliyanto
Postby wasliyanto » 14 May 2011, 11:03
sudah saya rubah natnya sesuai dengan petunjuk diatas namun saya pantau di ip address mikrotik ether5 yang terhubung ke proxy masih belum jalan walaupun disisi client banyak yang dowload dan browsing namun masih tidak sesuai dengan kecepatan yang ada di ether 2 dan 3 berkisar, client browsing sudah bisa jalan 586bps
yudiarbi
Postby yudiarbi » 14 May 2011, 16:39
kalo memantau proxy ya ditunggu beberapa saat, lakukan aktifitas di client, sambil jlnin perintah di server proxy tail -f /var/log/squid/access.log
wasliyanto
Postby wasliyanto » 14 May 2011, 18:28
cara melihat client ada akses dan bisa berfungsi cache nya bagaimana?
yudiarbi
Postby yudiarbi » 15 May 2011, 01:09
ya di atas itu perintahnya ke server proxy bos, sambil client melakukan aktifitas browsing...
wasliyanto
Postby wasliyanto » 16 May 2011, 19:38
Sudah dilakukan sesuai dengan petunjuk mas yudiarbi namun di proxy hitnya tidak bergerak, walaupun client melakukan browsing, apanya ya, yang salah, tolongin dong?
yudiarbi
Postby yudiarbi » 16 May 2011, 22:19
waduh..kok bisa bro, transparent proxy kan?coba diganti :
add action=dst-nat chain=dstnat comment="___DIRECT TO PROXY" disabled=no \
dst-port=80 protocol=tcp to-addresses=192.168.168.2.1 \
to-ports=3128
wasliyanto
Postby wasliyanto » 17 May 2011, 05:43
sudah saya coba bos tetep g bisa, malah client tidak bisa browsing bos,bagaimana ya? apa squidnya yang perlu dirubah ya?
yudiarbi
Postby yudiarbi » 17 May 2011, 06:43
yang ini ttp jgn di ilangin :
di tambahin ini :
rule2nya cukup itu aj, rule2 yg lain diapus, gmn hasilnya?gak perlu merubah squid krn overall ud bagus kok, asal acl di ganti sesuai jawaban saya di atas :D
wasliyanto
Postby wasliyanto » 17 May 2011, 07:03
coba bos acl nya diketikkan juga karena saya kurang jelas, ini sudah saya coba client sudah bisa browsing namun dilihat di hit nya ga jalan walaupun client sudah browsing
wasliyanto
Postby wasliyanto » 17 May 2011, 07:26
tolong bos penyesuain aclnya di squidnya di ketikkan krn saya kurang jelas,maklum pemula sekali
Users browsing this forum: Majestic-12 [Bot] and 38 guests
