ane baru kemaren pagi pake ubuntu..... :D tolong diban
zHaner
Postby zHaner » 07 Mar 2011, 14:48
aNe lagi apdate kambing.ui tapi selalu muncul>>>
Hit http://kambing.ui.edu maverick-security/universe i386 Packages
Hit http://kambing.ui.edu maverick-security/multiverse i386 Packages
Ign http://kambing.ui.edu maverick/restricted Sources
Ign http://kambing.ui.edu maverick/multiverse Sources
Hit http://kambing.ui.edu maverick/restricted Sources
Hit http://kambing.ui.edu maverick/multiverse Sources
W: Failed to fetch http://kambing.ui.edu/ubuntu/dists/mave ... ion-en.bz2 Error reading from server - read (104: Connection reset by peer)
E: Some index files failed to download, they have been ignored, or old ones used instead.
adie@adie:~$ ignored
ignored: command not found
adie@adie:~$ sudo gedit /etc/atp/sources.list
adie@adie:~$
kepa ya pak??
Re: ane baru kemaren pagi pake ubuntu..... :D tolong d
Postby offline » 07 Mar 2011, 16:19
kalau ganti mirror lain gimana om selain kambingnya UI?
Users browsing this forum: Bing [Bot] and 17 guests
