[Ask] Ini Kenapa ya?
barutahu
Postby barutahu » 28 May 2014, 11:51
Permisi agan semua.. saya mengalami masalah saat saya melakukan upgrade, mohon solusinya
afzal@afzal-AOHAPPY2:~$ sudo apt-fast upgrade -f
Working...
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
Calculating upgrade... Done
The following packages have been kept back:
linux-generic linux-headers-generic linux-image-generic
The following packages will be upgraded:
liboxideqtcore0 linux-image-3.13.0-24-generic
linux-image-extra-3.13.0-24-generic
3 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
128 not fully installed or removed.
Need to get 0 B/72,4 MB of archives.
After this operation, 1.024 B disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 166401 files and directories currently installed.)
Preparing to unpack .../liboxideqtcore0_1.0.0~bzr501-0ubuntu2_i386.deb ...
Unpacking liboxideqtcore0:i386 (1.0.0~bzr501-0ubuntu2) over (1.0.0~bzr501-0ubuntu1) ...
dpkg-deb (subprocess): decompressing archive member: lzma error: compressed data is corrupt
dpkg-deb: error: subprocess returned error exit status 2
dpkg: error processing archive /var/cache/apt/archives/liboxideqtcore0_1.0.0~bzr501-0ubuntu2_i386.deb (--unpack):
cannot copy extracted data for './usr/lib/i386-linux-gnu/libOxideQtCore.so.0' to '/usr/lib/i386-linux-gnu/libOxideQtCore.so.0.dpkg-new': unexpected end of file or stream
Preparing to unpack .../linux-image-3.13.0-24-generic_3.13.0-24.47_i386.deb ...
Done.
Unpacking linux-image-3.13.0-24-generic (3.13.0-24.47) over (3.13.0-24.46) ...
dpkg-deb (subprocess): decompressing archive member: internal bzip2 read error: 'DATA_ERROR'
dpkg: error processing archive /var/cache/apt/archives/linux-image-3.13.0-24-generic_3.13.0-24.47_i386.deb (--unpack):
cannot copy extracted data for './lib/modules/3.13.0-24-generic/kernel/drivers/hv/hv_balloon.ko' to '/lib/modules/3.13.0-24-generic/kernel/drivers/hv/hv_balloon.ko.dpkg-new': unexpected end of file or stream
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.13.0-24-generic /boot/vmlinuz-3.13.0-24-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.13.0-24-generic /boot/vmlinuz-3.13.0-24-generic
Preparing to unpack .../linux-image-extra-3.13.0-24-generic_3.13.0-24.47_i386.deb ...
Unpacking linux-image-extra-3.13.0-24-generic (3.13.0-24.47) over (3.13.0-24.46) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-extra-3.13.0-24-generic_3.13.0-24.47_i386.deb (--unpack):
cannot copy extracted data for './lib/modules/3.13.0-24-generic/kernel/sound/soc/snd-soc-core.ko' to '/lib/modules/3.13.0-24-generic/kernel/sound/soc/snd-soc-core.ko.dpkg-new': unexpected end of file or stream
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
-e
Done! Verify that all packages were installed successfully. If errors are found, run apt-get clean as root and try again using apt-get directly.
Re: [Ask] Ini Kenapa ya?
Postby thrvers » 28 May 2014, 16:16
hapus dulu file2 ini:
/var/cache/apt/archives/Linux-image-3.13.0-24-generic_3.13.0-24.47_i386.deb
/var/cache/apt/archives/Linux-image-extra-3.13.0-24-generic_3.13.0-24.47_i386.deb
lalu ulangi proses dari awal
Postby nif » 28 May 2014, 20:07
setuju dengan saran om thrvers di atas.
penyebab error karena file-nya corrupted;
barutahu
Postby barutahu » 29 May 2014, 01:25
Thanks gan atas pencerahannya dan sekarang sudah aman kembali :D
Users browsing this forum: No registered users and 41 guests
