Help Ask Ubuntu 10.04
YaRu
Postby YaRu » 27 Jul 2013, 18:11
kalo eror kaya gini biasanya apa ya
Setting up tex-common (2.06ubuntu0.1) ...
Running mktexlsr. This may take some time... done.
No packages found matching texlive-base.
dpkg: error processing tex-common (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of texlive-binaries:
texlive-binaries depends on tex-common (>= 2.00); however:
Package tex-common is not configured yet.
dpkg: error processing texlive-binaries (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Errors were encountered while processing:
tex-common
texlive-binaries
E: Sub-process /usr/bin/dpkg returned an error code (1)
maaf ban moderator kalo salah kamar.dipindahin aja
Re: Help Ask Ubuntu 10.04
Postby nif » 28 Jul 2013, 08:35
subprocess installed post-installation script returned error exit status 1...
sepertinya masalah di script postinst bawaan tex-common. jadi bisa dibilang, error dari sono-nya (pembuat paket) :confused:
omigasun
Postby omigasun » 29 Jul 2013, 08:04
kenapa masih pake yang 10.04 sih??? kenapa gag pake LTS yang baru?? 12.04
belthsazar
Postby belthsazar » 29 Jul 2013, 20:06
karena 10.04 masih suprot sampe tahun depan om. :grin:
YaRu
Postby YaRu » 31 Jul 2013, 09:15
he...alasa n atas ane emang bener. + ringan..udah bisa ternyata masalanya di bagian ini mas
Users browsing this forum: No registered users and 11 guests
